How can my users use the 123 website?
1027
6
03-21-2023 01:34 PM
DougBrowning
MVP Esteemed Contributor
On the https://survey123.arcgis.com/ there is no way for users to really use forms that they do not own.
There used to be a My Org option but that seems to be gone?  We work across Orgs also and I asked the team to enable use to see any form shared with us but it has not been changed yet.
There must be a way for all our users right?  What am I missing here?  I admit I do not really use the site much but we have some reports now and our users are struggling to use the reporting.  We have lots of forms so linking to each one is too much.
thanks a lot
wayfaringrob
Honored Contributor
Hmmmm, I do have the org tab....
DougBrowning
Yes I and others had it last year now its just gone.
Katie_Clark
Hmmm, strange, I also still see the organization tab when I view the website, so I can't reproduce the behavior you're seeing.
A silly question, but is there a chance it could be browser related? (i.e. try a different browser, clearing cache, etc.)
Also, are you able to view anything when you go to this URL directly?
https://survey123.arcgis.com/org/surveys
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
DougBrowning
Nope just goes back to the main page with no Org option.
Katie_Clark
Ok. And I see in your screenshot that you are logged in as "Doug"....is that your main account (an administrator, I assume?) Or an account with different user privileges?
According to this documentation, "You can manage all surveys in an organization and organization-wide settings for Survey123 on the Organization page of the Survey123 website. This page is only available to organization administrators or users with a role that includes the Organization website privilege."
You probably viewed that page already but figured it couldn't hurt to ask - just trying to throw ideas out there!
Best,
Katie
DougBrowning
Yep all the same as last year.  Our Admin does have the Org button so may be a security issue.  We just can't figure out what that may be since its all the same as last year.  thanks
