How can I combine day from different field using data expression?
794
03-22-2024 03:06 AM
RAMON_VERANO
I have another queries here regarding data expression.
I want to combine data from different field in survey123 then project it in arcgis dashboardso that I can visualize the percentage using pie graph.
I want to see the percentage of male to female.
jcarlson
MVP Esteemed Contributor
You can do that, but you don't need a data expression. Set the pie chart to "Fields", add your fields and set the statistic to "Sum".
- Josh Carlson
Kendall County GIS
jcarlson
- Josh Carlson
Kendall County GIS
