How can I calculate area when I have multiple equations for many feature types?
5179
27
03-11-2019 02:51 PM
KaitlynAbrahamson
Hi All,
I have another formula to create, but I am new to Survey123 and am not sure how to get what I need on the survey.  The project I am working on is sign inventory and the question I am having trouble with is with the area of each sign (200 different sign types).  I will have the width and height of each of the sign, but the signs, being all different shapes, have different area formulas.
These are all the different formulas:
(Width * Height)/144 (The majority of the signs have this equation)
(SQUARE(Height/12)) * .76
((1 + (SQRT(2))) * 2) * (SQUARE((Width / 12)/2.4))
(Height * Height /333)
(Width * Width * .0052083)
(Width)/12
(Width * Height)/182.5
(Height * Height * .0042918)
I have this for an equation (${SignWidth}*(${SignHeight})div144) for the majority of the signs, but the more advanced equations I am clueless on.  If you know how to write out some of these, that would be very helpful.  I am not even sure which survey column I should be writing these in either (calculation, relevent, etc.?)
I think I am in need of a very intense, nested if statement, but maybe it needs to be broken up in some way. I've included what my data looks like for reference.  Please help!
DougBrowning
MVP Esteemed Contributor
Have the last equation just show you the value ( without the if part) and see what value it is getting.  It may be a ‘’ if hidden via a relevant.  If so adjust your if.
Jim-Moore
Hi Kaitlyn
Just to confirm, Doug Browning is right regarding pulldata - using pulldata in the calculation column to pull a formula from a CSV won't work; the formula would simply be returned as a string rather than being evaluated as an expression.
Sounds like you're making progress with your if statements and calculations!
Best regards,
Jim
KaitlynAbrahamson
Thank you for your help!  I ended up trying to use the pulldata function, but am having little luck.  My data is not showing up and I am not sure what is wrong.
Jim-Moore
Hi Kaitlyn, how are you using the pulldata function? Would it be possible to share your XLSForm and CSV so I can see how your survey is structured? Thanks, Jim
KaitlynAbrahamson
Hi Jim,
I have ended up restructuring my survey so many times.  I am using the pulldata function to pull what I can for width and height so I can calculate area.  It's working well, but now I have run into needing a nested if statement will all my formulas.  The syntax is killing me when I try to put them all together.
KaitlynAbrahamson
On top of that, when I try to do a calculation with even one of my formulas, the area does not change if I alter the width and height in the survey.  I'm not sure Survey123 is that dynamic.
BenjaminHanzen
Hey Kaitlyn,
I hope things are going well for you!
I'm not sure I fully understand the question. Is there a criteria that is met in order to determine area calculation? I'm guessing if its octagonal such as your stop sign you use a certain equation correct?
Might I suggest you use the look up function where you define each sign with the equation so that it pulls that equation for that criteria. I wonder how you're setting up your pull data currently that you are still looking to use nested statements.
Survey123 for ArcGIS – XLSForm: Enabling CSV Data into your Survey - YouTube
Let me know if that helps. Nested if functions are exhausting.
AbdoAbdelrasoul1
I think first you need to identify scenarios for each equation to use, then come up with code for each scenario/equation e.g. 1, 2,3 for people to enter in the field/office, also you can add another field for exceptions, then query each code (may be with exception) to apply the right equation.  Good luck, Abdo
