How can I add a repeat to my published Survey123
2861
7
06-20-2022 06:34 PM
Survey123Jedi
Is there a way to add a repeat to my published survey without building a new one and appending the data?
DeonLengton
Looking forward to the answers on this one, but I doubt there's a way without appending.
IsmaelChivite
Esri Notable Contributor
Unfortunately not. When you add a repeat to your survey, Connect will not be able to simply add the related table to your existing survey layer. Instead, it creates a new layer. Some options that come to mind:
Option 1:
  • Export your existing records into a File Geodatabase
  • Add the new repeat and publish (this will re-create your layer and empty it)
  • Append to your new layer the data you exported
  • Keeps your survey item id intact.
Option 2:
  • Do a save-as of your original survey
  • Publish
  • Append data from the original survey into the second
  • Creates a new survey item id
Option 3:
Survey123Jedi
Thank you for these suggestions @IsmaelChivite
Option 1 - I've never considered overriding the service on purpose (to keep the id intact).
I will try these next week. : )
CORFOPYM_Ingenieria
I have tried the first option, but i lost the attachments. Any solution???
DeonLengton
@IsmaelChivite Does Option 3 mean that the data does not get deleted?
MikeOnzay
Technical Support has a detailed step-by-step article for this situation. I've followed it twice.
EricaNova
That article link is broken - do you think there is a way to find it?
