Hosted Table to Survey123
794
09-11-2017 05:54 AM
LindaRadomile
Hi All.
Im wondering if its possible to create a form from an existing hosted table instead of a layer?  I tried to create a new form but it seems to keep crashing Survey Connect using the table.  My intention was to create an inspection table, containing all records for multiple locations and inspections. I dont have a need for a point feature class, eventually I will be using barcodes to populate the lat/ lon information into the form.   Thoughts?
JamesTedrick
Esri Esteemed Contributor
Hi Linda,
Yes, it should be possible to use a table.  Can you describe how the table was published into a feature service (as a feature service requires 1 layer that does have geometry)?  Is it related to the layer?
