Hint and guidance_hint do not work correctly in table-list
1151
06-26-2024 09:14 AM
jcfernandes
Hello,
In Survey123 Connect, I want to use the hint and guidance_hint, but they are not configured on the correct lines. Instead of appearing below the question they are configured for, they appear above it.
Could this be an error?
Thank you
Best regards,
João Fernandes
Lei_Liu
Hi jcfernandes,
Thank you for sharing your findings. Regarding your observation of hints and guidance appearing above the label, I recommend submitting this issue as a bug via Esri Support.
Once submitted, our Support team will assign an official bug number for your records. This number can be used to search for and subscribe to updates on the Esri Support site. If other customers report the same issue, it will be linked to the same bug report, which helps us assess the impact and prioritize it accordingly.
Lei
NathanialWigington
I am having the same issue with one of my surveys. The "Hint" text appears above the question when using table-list appearance.
DataOfficer
I am also seeing the same issue. When table-list appearance is used within a group, the hint appears above the label.
DataOfficer
I logged this issue with ESRI Support and they confirmed it is a BUG. Here are the details:
This is a known issue and has been logged as a bug. Details and a workaround can be found here:
