Hidden Fields in App
1999
01-24-2023 02:01 PM
jbrower
Hi everyone, I need a bit of help completing this last portion of my survey. Using Survey123 Connect Version 3.15.175 and Enterprise 11.
So I'm using a select multiple list to have certain textboxes appear when they select certain answers. The web app appears to do exactly what I want, only show certain boxes when certain answers are selected. But for the app, even when nothing is selected the boxes are still there.
I'm using the integer type and using selected(${column_viol_type}, "violation1") in the relevant column.
The select multiple is select_multiple violations, and the type has 13 different answers to select from.
Any help would be greatly appreciated.
Richard_Purkis
Hi @jbrower
May you share the xlsx form and identify which rows apply to the issue. I wasn't able to recreate the issue in a simple test
Thanks
jbrower
I can share a sample from it. The issue applies the same to the 13 pages I have so I have an example from the redacted xlsx.
Richard_Purkis
@jbrower
I can partly recreate the issue. The field isn't there upon launch but it doesn't return to not shown under certain workflows
Is this what you are seeing?
Thanks
jbrower
Sort of. When I edit the survey in Survey123 Connect, that empty space underneath has boxes where the boxes would come up if they were checked. Here is a picture example from Survey123 Connect and the Web viewapp view.jpgwebapp view.jpg
SWT_TL
Was there ever a solution to this @Richard_Purkis?
I also have a form with multiple hidden questions preventing the app view being user friendly.
I would use the web form but there is an issue there with the autocomplete search() appearance not working for users without a full licence.
