Hidden field responses not appearing in the Analyze and Data tabs
1344
12-12-2017 05:19 PM
Trippetoe
I followed the wonderful example by Carmel Connolly (Making Other Work Harder in Survey123 Results — Esri UK)
to collate 'other responses' into a single field (Section 2), and it worked great..... except when i view the survey results in the Survey123 website. In the Analyze tab, i see a message which reads 'no questions are visible....' I clicked the Set Visibility button and selected the 'All' check box. Still no questions are visible. In the Data tab, when i click on an individual record, in the right hand pane i see the title of my survey and the 'submitted by' and 'submitted time' fields, but that is all.
As a test, i changed the hidden field to 'text', republished the survey, and submitted some new responses. Now i can see all the responses in the Analyze and Data tabs. Is the Survey123 site supposed to hide the responses to 'hidden' questions?
JohnathanHasthorpe
Hi Tom
Hidden fields are not currently supported in the website. We do have an enhancement request open for this and will add you to it. Additionally, there is a bug affecting the handling of select_one or select_multiple questions using or_other. This should be addressed in 2.6.
John
JohnathanHasthorpe
Hi Tom
John
CarmelConnolly
Hi Tom,
Good spot! I'll add that to the blog
Carmel
ZhifangWang
Hi Tom,
Would you mind sharing the XLSForm file with us and also with some screenshots? In the next 2.6 release, we have an enhancement for detecting "Other" choice better on the website, not sure if this enhancement will fix your issue.
Trippetoe
Screen shots below. I am not sure how to upload the xls form.
In the first screen shot, the 'All' checkbox is selected in the 'Set Visibility' dialog.
