Hi All, Is it possible to collect data from multiple survey record in a single feature report?
739
01-20-2020 01:54 AM
HusamAllthawi
feature report, multiple records
BrettStokes
Hello Husam,
This is possible in v3.8 of the Survey123 website (that will be released tomorrow)!
In the 'Data' tab, you can select or filter the survey records you'd like to include in the report (or choose the 'all records in the table' option). You will see the new 'File options'. Here you can choose 'One report for each record' or 'Multiple records in a single report'. The latter option will present your chosen survey records in a single feature report.
Version 3.8 of the Survey123 website also brings with it the ability to produce a preview sample PDF report (to ensure your template is set up properly without consuming any credits), and the option to choose either PDF or DOCX output formats.
Hope this helps,
Brett
BrettStokes
Hello Husam,
Hope this helps,
Brett
HusamAllthawi
Sounds great Brett, that will be very useful,
thanks so much.
