HELP my surveys disappeared.
820
03-04-2022 03:48 PM
ErinAas3
My survey folder in ArcGIS online disappeared (I swear I didn't delete it.)  All the survey's still exist in the
C:\Users\xxx\ArcGIS\My Survey Designs -  is there anyway to publish them from there?
Katie_Clark
MVP Alum
If they still exist on your local machine, then you should be able to republish them from Survey123 Connect. However, it does seem like strange behavior if you didn't delete them yourself. Have you tried getting in contact with Esri Support?
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
MVP Alum
Best,
Katie
