Help! Inbox Not Returning Repeats
2157
07-08-2021 06:44 AM
JoshHabel
Hello,
I am having troubles getting my repeat answers to show up when i go to edit through the inbox. My workflow  requires that i have a survey with a single repeat that i want one group to complete.  A second group will edit the repeat answers if necessary through the inbox so they need to be able to see what the previous answers were.  I set allowUpdates=true in the bind::esri:parameters column for the begin repeat row and republished the survey but this did nothing.  When i open the sent survey through the inbox it doesn't pull in any of the previous answers.  Am i missing something??? I have also tried adding quote "" marks around the allowUpdates=true but this has not worked either.
Josh
Tags (4)
IsmaelChivite
Esri Notable Contributor
IsmaelChivite
JoshHabel
That worked!
Josh
