hello, i am trying to build a process between survey123 (on portal 10.6.1) and integromat
i have this error message :
Function 'GetAttachmentUrls' finished with error! Unexpected token o in JSON at position 1
i had tested the process first on agol.
Hi Delaere,
This is apparently due to a difference in feature services in ArcGIS Enterprise and ArcGIS Online. We are looking into how to resolve this.
Thank you James,
i am waiting for the update.
Great thanks James, I was really excited to see the Integromat connector now supports Portal so looking forward to this being resolved.
Is there a way to disable integromat from trying to pull the attachment URL's that we could use at the moment?
Hi Andrew,
The problem seems to be resolved in 10.7.1.
I tried to ignore the error in integromat, but with no succes.
Hi Mikael,
Thanks for the reply - you managed to get it working at 10.7.1?
I'm using 10.7.1 (both Portal and Server) and hit the same error, even with surveys with no attachments. This is a feature service hosted in ArcSDE rather than a hosted feature service, maybe that's where the differences are introduced that aren't compatible with Integromat.
Will wait and see
Andrew
