Geotrace and Geoshape sum from points repeat not working
735
03-11-2024 09:43 AM
EmilieBly
I am trying to generate lines and polygons from points in a repeat.
I follow what is described in this post where a line feature connecting points nested in a repeat is generated.
I use the expression "sum(${point})" in the calculation column to generate the line :
When setting up the form in Survey Connect, the preview works well, the line is generated properly :
However once the form is published and used online, the calculation for the line runs indefinitely (even when changing the points in the repeat).
When the form is submitted, the results do appear in the Feature service (the points are present in the point layer as well), however the line geometry associated with the record is empty, but the other attributes are populated.
I have this result whether I generate a line or a polygon.
I am unsure of what I am missing to make this work ?
Thank you very much for your help.
estelleseremes
Hello, I ran into the same problem. Does someone find out why that is ?
