Formatting date in Survey123
40347
20
10-05-2016 01:48 PM
bobwright
Greetings. I've read Ismael's post regarding this, but it doesn't address the specific question I have. I understand that using the type "date" results in 10/5/16 12:00, but I would really like it to be 2016/10/05 12:00 so I can sort properly on them (10/21/16 sorts before 10/5/16 for example). The type "datetime" results in 16/5/10 which doesn't help much either. Changing the date format in the Regional settings of Windows does not help any. Suggestions? Thanks.
Tags (1)
MaureenPeniuk
Day month year, will work for us for now.
That is better than having the month in the middle at least.
Maureen
MaureenPeniuk
Both Canada and South America display as / year month day/ in the form.
In the on-line data table it reverts back to month day year and the am/pm
time.
Maureen
FRSadmin
I am trying to get this to display seconds using `%h:%M:%S` but it will only show seconds as 00 in survey123...
Is there anyway to autofill the seconds part using the now() data?
VictoriaDavis1
I have a date question appearing as year only which is ${study_year}. The user can select what year the assessment was done in the past.
I want another question that is an integer, and autopopulates like:
int((today() - ${study_year}) div (1000 * 24 * 60 * 60 * 365.25))
It works fine in the app but when i publish it, it no longer works? What am I missing?
SarahWhitton
I am trying to format my date, for example if I select today's date, December 4, 2018 I get 1543899600000. I added a hidden line with a calculation, as follows, format-date(${ReportDate},'%d/%m/%y') . I would like to reference this new formatted date in a calculation, which will produce an email (shown below).
When I insert the hidden line for the format-date, I get an error.
JamesTedrick
Esri Esteemed Contributor
Hi Sarah,
What is the error that you get after adding the hidden line?
MichelleWilliamsERM
Is it possible to get this to work? I'm getting the UGLY Number right now:
typenamelabelcalculation
select_one yes_noBMPsRequiredNew/Additional BMP Needed
textBMPRepairStatusUGLYBMP Repair Needed Dateif(${BMPsRequired}='Yes', now(), 'None')
textBMPRepairStatusBMP Repair Needed Dateformat-date(${BMPRepairStatusUGLY},'%Y/%m/%d %H:%M')
AmyHarrigan
Is it possible to get the year format in a spinner appearance rather than in a tab to the before or after year?
JamesTedrick
Hi Corey,
Can you clarify a little bit?  The year appearance already act much like a spinner appearance:
Are asking for the forward/back areas to be separate buttons?
AmyHarrigan
Suppose I was looking to see if there was a way to display year the same way you would for time.
