Format numbers in Survey123 Feature Reports
2310
07-22-2021 11:18 AM
BrandonA_CDPH
I am working on a Survey123 Feature Report Template. I have a location ID number (i.e. 12345) and I am trying to display it without a comma. Is there a number formatting command I can use to override the default comma placement? Right now, the number prints as "12,345". I would like "12345". Thank you in advance for any advice or direction.
Ruth_JiatengXu
Hi @BrandonA_CDPH ,
Thanks for sharing here! You could try ${locationID | useGrouping:false}.
If you want to know all the expressions that are available, you could check the quick reference page:
Ruth
Ruth_JiatengXu
Hi @BrandonA_CDPH ,
Ruth
BrandonA_CDPH
Hi @Ruth_JiatengXu,
Thank you for the solution and the tip on the expressions.  Appreciate the help.
Brandon
