Force user to give a specific answer to be able to submit data
1604
09-17-2020 03:25 AM
Andre_Oliveira
Hi all,
Im working on a survey to have it on web but im developing it in Connect. I have a selec_one yesno question and I need to force the user to chose 'yes' in order to submit. In order to achieve this, I made a hidden and required field with:
Relevant: ${yesno}='yes'
Calculation: ${yesno}
It works perfectly on Connect app, I cant submit data if I dont answer anything or answer 'no'. But in Web this does not happen. Any ideas where the problem might be? Any workaround?
IsmaelChivite
Esri Notable Contributor
Hi.I am attaching an XLSFile that I believe does what you want.
A constraint in your yesno question should do the job.
Applying a constraint to a hidden question is not a good idea as there is no good way for the app to highlight the error (since the question is hidden).
Hope it helps.
Andre_Oliveira
I guess that works as well. But it's not exactly what I had in mind. Currently what im doing is only give the 'yes' option and it's a required field. But it's also not what I had in mind.
You bring up a good point but in Connect app, it works perfectly. I have the hidden question but if the user doesnt give the 'yes' answer, the constraint message from the hidden question still pops-up.
