Filtering by Date in Autocomplete Search Questions
338
07-21-2025 11:06 AM
GISAdminMLTMUA
Hello,
I am using Survey123 Connect 3.23 to build a survey with an autocomplete search function. The question pulls from the results of another Survey123 form through a REST endpoint. I have the autocomplete search question working properly, but I need to add a filter to the results to only show entries from the past 7 days.
I have a 'submitted date' field in the 1st Survey123 form that I am trying to use to filter. The way I have tried to filter the results is: submitted date > current date - 604800, after the main text in the 'appearance' field.
I have done a good amount of research and trial/error and I cannot come up with the correct syntax to get this question working properly.
Thank you!
ChristopherCounsell
MVP Frequent Contributor
search(tableName, searchType, searchColumn, searchText, filterColumn, filterText)
The above is the expression you need to use for search()
You can use a SQL Where expression within the tableName parameter to filter the table. e.g. if submitted_date is your field:
"layerName?url=https://yourserver/FeatureServer/0&where=submitted_date > CURRENT_TIMESTAMP - INTERVAL '7' DAY"
You would need to update your other parameters but it would look like:
search("layerName?url=https://yourserver/FeatureServer/0&where=submitted_date > CURRENT_TIMESTAMP - INTERVAL '7' DAY", searchType, searchColumn, searchText, filterColumn, filterText)
https://community.esri.com/t5/arcgis-survey123-blog/dynamic-choice-lists-using-search-appearance/ba-...
https://doc.arcgis.com/en/survey123/desktop/create-surveys/xlsformsappearance.htm#ESRI_SECTION1_46A7...
ChristopherCounsell
Town_of_Fuquay-Varina_GIS
<woops can't delete>
CalvinHarmin
I'm not sure if this is relevant, but AGOL stores dates as epoch milliseconds. I noticed your math is using 7 days in seconds, 604800. I wonder if you would need to add three zeroes to that, otherwise you are only subtracting 0.007 days?
