Field automatically created when using repeat_count
1322
06-06-2018 11:19 AM
OlivierDemars1
When using the repeat_count column, why is there a field (<repeat_name>_count) automatically created in the schema?
I would like to remove this field from my geodatabase.
Olivier
JamesTedrick
Esri Esteemed Contributor
Hi Olivier,
The _count field is being generated by the form conversion process.  It should be addressed in the next release of Survey123.
JamesTedrick
Hi Olivier,
OlivierDemars1
Thanks James
