Feature layer in survey 123
481
12-11-2020 09:28 AM
Moe
Hello!!!
Can I design the survey 123 to display the existing feature layer for referencing during the field work?
Thanks.
Moe
BarbaraWebster1
Hi Moe,
Yes, you can configure a web map and link it to your survey for use in the field. If you're going to be in a disconnected environment you can also set up an offline map in your survey.
The Link an online map to your survey section of the Include a map in your survey documentation has more details on this.
-Barbara
