Failed to Save: Cannot read properties of undefined (reading 'replace')
645
03-06-2025 02:47 PM
Bailey_Briggs
Hi, I'm having an issue with an existing form, when I try to share results to a group in the collaborate tab -> share results, it says Failed to save: Cannot read properties of undefined (reading 'replace'). This is the only setting that throws that error, as I can change the share survey, update survey, etc., settings. Specifically, a problem with 'sharing results' to anyone.
I confirmed that all related and linked content (web maps, hosted/view layers, dashboard) is shared with the same group, same sharing settings, and all exist within the same folder. This survey was shared with that same group a week ago and they had access to the data, and now they don't, seemingly overnight.
No issues with the form itself as entries can still be made, I analyzed and republished it to make sure. This seems to be only affecting the survey123 website, or the share results settings. Not a group specific issue as I can't share results with anyone (org or public). Any advice would be appreciated, I can provide more information if need be, just not sure what is pertinent. Thanks!
Tags (1)
DavidPike
MVP Notable Contributor
It may be something to do with the Hosted Feature Layer View _results if it has properties that may have been modified outside of the Survey123 site.  I might be tempted to delete the _results view and retry - or set the sharing within ArcGIS Online from the Hosted Feature Layer and View.
LinzMess
I am having the same issue. However, when I published my survey via Survey123 Connect, a view layer was never created (or it is possible it was deleted by mistake/not understanding it was needed). Members of the shared group are able to collect survey data and edit it via webmap just fine. I was able to create a report template and as the survey owner, I can run reports via Survey123 website. I am able to adjust the "share survey" settings on the survey123 website, but am unable to modify any of the "share results" settings and get the error @Bailey_Briggs mentions above. I realized I needed to change the "share results" settings in order for shared group members to be able to run reports. Is my error related to not having a _results view?  I did create a hosted view layer outside of the Survey123 website and the title I gave it was the same as the hosted feature layer with _results at the end. I then retried "share results" settings via Survey123 website "collaborate tab" but that did not change the error I receive.
