Extract field and concatenate
1855
04-13-2022 09:43 AM
AliciaShyu
Survery123 Connect 3.13
I have a text field (RollCallNbr, row17) in the following format xx-xxxx. The first 2 characters represent the year. I need to extract those 2 characters, convert them into 4 characters for year (RollCallYear, row 18), and use the new year field as part of a concatenated URL (RollCallURL, row 19).
For example:
A roll call number can be 22-0501, the roll call year would be 2022 and the roll call URL would be https://councildocs.dsm.city/rollcalls/2022/22-0501.pdf
I'm attaching the XLS form.
Katie_Clark
Sounds like you should be able to use the substr() function to extract the first two digits. Here's how I would go about it.
  1. Add a new row with the substr() function in the calculate column to populate this field with the first two digits of the roll call number.
    1. substr(${RollCallNbr}, 0, 2)
  2. Create the four digit year by adding concat("20", ${twoDigitNum}) to the calculate column of the ${RollCallYear} row
  3. Create the URL by using concat("https://councildocs.dsm.city/rollcalls/", ${RollCallYear}, "/", ${RollCallNbr}, ".pdf")
Hope that works for you!
Best,
Katie
If this answer helped you, please consider giving a kudos and/or marking as the accepted solution. Thanks!
Katie_Clark
Best,
Katie
AliciaShyu
Thanks Katherine!
That worked, I only had to make a minor change in step 1, substr(${RollCallNbr},0,2)
Katie_Clark
Ah yes, I couldn't remember if the indexes started at 0 or 1 with Survey123. I updated my original response.
Glad it worked! 🙂
Best,
Katie
