I'm using cascading selects to quickly filter down the choices for a room number/id for a building. Otherwise users will scroll through ~13,000 room ids.
-I can create a regular cascading select where the cascading select_one choices work great. However, I get an error 499/ gateway timeout when publishing because the choice list has over 10k values for the largest list series.
-When I convert it to an external cascading select, I can publish the survey, but the choices that are in the external_choices tab do not show up in the form.
I scoured GeoNet, and found nearly the same question unanswered. See:
External Cascading Select Not Working for an identical problem that is unresolved. (suggest solution: make unique column names that are not the same as list names. I tried that, no resolution)
and external select stopped working works for the questioner and though I tried it, it did not work. (suggested solution: ensure the label::language1 was set to label::English (en) on all forms)
Any ideas of how to solve this?
Update 9/16/2020.
After working with ESRI Support I have the following information:
The Choices sheet has an upper limit of 4837 items per list set. No known upper limit on External Choices.
Since the External Choices is stored as a CSV ensure the following.
-There are no commas anywhere in the Label field (or anywhere else)
-There are no Carriage Return (CR, ASCII code 13) or Line Feed (LF, ASCII code 10) characters in the Label field. Use 'Find and Replace' with 'Shift+J' to search for Carriage Return. Surveys viewed on a browser will work if there are multi-line characters, but Android and iOS devices will not.
-My room ids are numbers as String, Excel will flag them with an error indicating 'numbers stored as text'. You must format them as text by clearing the cell error - Ignore Error or create a helper column with the =Text formula, then copy paste values over your original data. (Then delete your helper column)
-Delete the Itemset.csv in [Show survey in folder]/Media folder. When you publish a new one will be created reflecting all the changes you made on External Choices sheet.
I have gotten my survey working!
For Anyone Else searching for the answer to this/similar problem and want to save time when asking GeoNet or Opening a Support Ticket to let them know this isn't the problem:
-Confirm there are no special characters in the any of the 'Name' columns in your tabs.
-Confirm you are using only select_one_external with choice filters for you external_choices tab
(From https://support.esri.com/en/Technical-Article/000021767)
James suggestion above was where I started when I posted to this forum but gave me the idea to try NOT having all my choices with choice filter to the external tab. I moved the smallest list (with 239 choices) back to the regular choices tab. Et Viola the survey works! Note: my smallest list was also the first question to use a choice filter after a Begin Repeat.
Is it a fluke? Why does it work? Is 239 choices a "small" set and okay to stay in the choices tab vs external_choices tab where "large" sets need to go? Is it because the Select_on/choice filter is direct after a begin repeat instead of a preceding select_one that will populate the choice filter? I do not know. Wish I did so I and others can avoid this glitch in the future.
Good Luck Y'all
Hi Sarah,
This seems like an issue that has come up with another customer. Can you try moving all the choices that use choice_filter to the external choice column?
Yes, this is already the state of the form. As in, I already have all the
choices that use the choice_filter in the external choice tab.
There are three questions that use the choice filter starting with a select
one/choices question (this gives the first value for the choice filter for
the external choices). The count of external choices for each question is
238, 1799, and 13358 respectively. I use the choice filter to narrow down
the options for each survey form drop down based on the
preceding choice_filter.
Good Luck Y'all
