Excel file export tabs out of order
448
03-08-2023 06:23 PM
AKitch
Hi all
I've noticed an issue when I export Survey123 data to Excel file from the Survey123 portal https://survey123.arcgis.com/. The excel file has the 3rd tab (out of 4) placed at the end of the tab order. This isn't the case if I export the data to Excel via the ArcOnline portal where all the tabs are in the correct order.
This issue has implications on my post processing code which picks up the tabs via their index. I know I can find the tabs via tab name but I suspect the inconsistency between portals is a bug. Has anyone else experienced this? Is it a user error?
Regards,
Adrian
