I have been working on a form using Survey123 Connect and am trying to use PullData to fill in existing data from a .csv file but I keep getting errors on those fields with the pulldata command and I was wondering if I had something formatted wrong. I have posted screen shots of the error message along with a screenshot of one of the fields that it is saying it has an issue with. While the error screenshot shows just one of the csv files it extends to the others as well, but I have tried everything I can think of to get the error to clear and I think that if I get the one instance to clear, I will know how to clear the others. Any help in clearing the error will be much appreciated.
Could you please attach your XLSFile (no need to attach the CSV files).
Added this morning 10/31/2017.
Hi there,
The error message actually continues down (but is not immediately visible). At the end is:
At lines 28 - 32, you have several pulldata() questions that refer to themselves; for example, the OwnerName question's calculation is:pulldata('06132017CCParcel','Owner Name','Parcel_Number', ${OwnerName})
and is referring to it's own value.
So how do I set it up so that it pulls that data from the csv file to populate those fields? I have changed those fields to reference the ReportingAddress name at the top of the survey which will likely be brought in from workforce (new issue to solve at a later date) and I continue to get errors. If the functionality of importing data from csv files were part of the online builder I'd just modify the online built form that I have right now to solve these issues and be done with it, but right now this is the best option and reading and rereading the blog posts about pulldata and watching 2 minute videos about it isn't getting me any closer to the end result.
Just to check, the ReportingAddress question is the unique lookup value? This is somewhat difficult to debug without a sample of the csv files that will accompany the survey.
Signed in members can post, follow updates, and more. New here? Register a free account.
