error in flows power automate : a is undefined power automate survey123
1146
03-02-2023 03:19 AM
chargeetudeti
Hi
All existing flows between power automate and survey123 are functional. But, it's impossible to modify them because of this the error message : "a is undefined" (see picture).
If i create a new flow, i have this error message :URL d'ARGuis is required, and so its impossible to save this flow (see picture).
ZacharySutherby
Hello @chargeetudeti
This is a defect with the Survey123 templates in Microsoft Power Automate. This has been logged as BUG-000155504.
To work around the behavior either remove the Survey123 connector and readd it or select My flows > New flow > Automated cloud flow and select the Survey123 connector.
Thank you,
Zach
ZacharySutherby
Thank you,
Zach
