Error 400 Unable to add feature service definition
2100
03-29-2021 03:14 PM
EddyClark
Getting Error code 400 - saying [CREATE TABLE failed becuase column 'example1' in table...
I'm not seeing duplicates.  So I moved the 'example1' column down to the bottom, tried again, and I'm then I get an error on 'example2' column.
I'm guessing I have too many fields.
DougBrowning
MVP Esteemed Contributor
The very first row has a reserved word.  That is what the mark is for.  Not sure if that it is or not but maybe.
That is a lot of fields though!  Not sure why you have one per agency a lot.  Hope that helps
EddyClark
Thanks for the help.  I found the error log, turns out I do have too many fields.
DougBrowning
I can only find the specs for a File Geodatabase.  Not sure what AGOL is but 1400 would be way lower.
File geodatabase size and name limits are as follows:
File geodatabase size: No limit
Table or feature class size: 1 TB (default), 4 GB or 256 TB with keyword
Number of feature classes and tables: 2,147,483,647
Number of fields in a feature class or table: 65,534
Number of rows in a feature class or table: 2,147,483,647
Geodatabase name length: Number of characters the operating system allows in a folder name
Feature class or table name length: 160 characters
Field name length: 64 characters
Text field width: 2,147,483,647
EddyClark
This is what the error log says:  error: {
"code": 400,
"details": [
"CREATE TABLE failed because column 'wus_urban_bv_mar_Calc' in table 'service_33x5e5902cb34f2ea25b09335c03f53e_GROUNDWATER_EXTRACTIONS' exceeds the maximum of 1024 columns."
"message": "Unable to add feature service definition."
DougBrowning
Oh found it is 1024 for 123.  You close.  Looked like there are ways to consolidate some in there.
https://community.esri.com/t5/arcgis-survey123-questions/maximum-number-of-attribute-fields-in-agol-...
