Enterprise Hosted Feature Layer Not Syncing with SDE Data
1033
03-17-2025 06:20 PM
LeviCecil
I have a standalone table in an Enterprise 11.3 sde geodatabase. I've published this to our Portal as a hosted feature layer and created a survey from this. The problem I'm running into is that survey submissions are only showing up in the S123 dashboard, not in the hosted feature layer or the sde table. I've enabled editing, global IDs, sync and editor tracking and the problem persists. I was having trouble setting up sync because of Time Only, Date Only and Timestamp Offset fields, but that doesn't seem to be the issue. Unless it is?
LeviCecil
Figured it out. I needed to publish the table as a reference registered feature service, not a hosted table, with replica tracking enabled and sync disabled on the sde table.
LeviCecil
I republished the sde table without the timestamp offset field. Now the new records are showing up in the hosted table in the portal, but still not in the sde. Do I need to enable sync for this to work?
LeviCecil
