Enabling photo pop-ups on an existing feature service built survey
463
11-01-2017 08:28 AM
MorganTitus1
I am wondering how you would build a non-federated ArcGIS Server Feature service (with the intention of building a Survey123 survey on top of it), such that it can direct the photo questions from the survey into photo attachments in the feature service and be able to support pop up's in Portal?  Do you need to set up or enable any attachments on the feature service prior to building your survey on top of it?
Essentially my goal is to have the data on  my server so I don't have to deal with exporting the data off of AGOL and re-creating a service on our Portal.
Any help would be much appreciated!
JamesTedrick
Esri Esteemed Contributor
Hi Morgan,
Survey123 supports this- in particular you should read connect to nonfederated ArcGIS Server services as well as Use Survey123 with existing feature services—Survey123 for ArcGIS | ArcGIS
