I would like to know if there is a way to enable the edit sent surveys option for a survey which has initially been published without it. The survey contains nested repeats & images.
I tried enabling it in the options and by adding 'allowUpdates = true query' to the bind::esri:parameters column, however, when I try to republish it, it throws an error saying that 'Table *survey name* could not be found' and that the feature service will be deleted and re-created, which is not what I want, the goal being to enable editing of the data within the Survey123 field app. I saw posts on how to solve this publishing error but not sure whether those are applicable to my case as it has not solved anything (yet).
An alternative, though less desirable, would be to copy all the sent data (including repeats & images) from the initial survey to a new one where the option is enabled. I have not yet been successful in doing so.
Any help will be greatly appreciated.
J.
