Is there a way to load the survey choice lists from an existing web or feature service?
The use case is that we have approximately 30 surveys deployed to 20 users and each survey has a select one question to populate the field contact. This field contact list changes monthly and we would prefer not to republish each survey on a monthly basis to refresh the contact choice list.
Let me know if you have a existing solution or if dynamic loading of survey choice lists are on your radar.
- Jake
