Dynamic content not creating for Survey123 fields
2023
6
05-26-2023 05:19 AM
OgunfolajiDare
I am working with Power Automate for the first time, hoping to automate the process of taking data collected in Survey123 and automatically populating an excel spreadsheet. I've been following this workflow:
https://www.esri.com/arcgis-blog/products/survey123/constituent-engagement/instantly-load-survey123-...
However, even though I believe I've set the table up correctly (and it's clearly pulling in the column names) I am not able to enter any field values from dynamic content
2 Solutions
OgunfolajiDare
Thanks so much, your observation was helpful the problem is resolved now. I have removed the map question and it worked. Kudo to you sir.
Catherine_Hodde-Pierce
Additionally, a coworker recommended deleting the map question, setting up the flow, then re-adding the map question. That work around was successful!
CoffeeforClosers
Does your survey have a map component? We were notified by ESRI Customer Service of a bug where having a map in your Survey prevents the pulling of dynamic content in Power Automate.
OgunfolajiDare
CoffeeforClosers
You're welcome. Please mark this question as answered.
@CoffeeforClosers Thank you for sharing this information! I was running into the same issue.
Do you happen to know when Esri intends to address that bug? Having a map question is pretty vital to Survey123!
Ogunfolaji_Dare
No, but I think they are working on it.
