Good Morning is is possible to display Hints when going to to print individual responses from the data tab? I appreciate any help with this.
Thanks
Dan Senner
Solved! Go to Solution.
Hi Dan,
Do you mean to display the hints you have set in the survey xlsx form (for each question) seperate to the label, as a text field on the report? If so, no this is not possible. Hints are used for data entry purposes in the survey to assist the user with entering data, therefore they are not printed in reports. If you want to see hints in reports, you could create them as notes in the survey, and that way they can be printed.
Phil.
Hi Dan,
Phil.
