Display all geometries of repeats on map when entering new repeat records
1263
04-04-2024 05:14 AM
JoshB123
I am developing a Survey123 form for habitat assessments which uses nested repeats to link species lists to each habitat polygon in a geotrace question (within the first repeat).
1) The main geotrace question records the site boundary
2) The first repeat geotrace question records each habitat parcel
3) The nested repeat records all species within each habitat parcel
While drawing habitat polygons on a survey it is important to be able to see all of the entered polygons for the previous repeat records so that boundaries of each habitat parcel can be aligned.
Question - Is it possible to display all polygons of each repeat record in the background of the geotrace question as they get added through the survey so the surveyor can see where they need to draw the next polygon on the map?
Thanks Josh
ZacharySutherby
Hello @JoshB123
We have an `overlay` parameter but unfortunately only supports geopoints at this time and does not work with geotrace/geoshape.
We have an internal issue to support geotrace/geoshape in the future. Please feel free to reach out to Esri Technical Support to log an Enhancement for this feature.
Thank you,
Zach
ZacharySutherby
Hello @JoshB123
Thank you,
Zach
ALBJORGUI
Hi @ZacharySutherby
Is there an estimate for this enhancement? shall I record it as an idea in the forums?
KristenPonak
Hi @ZacharySutherby Is there an ETA on adding in the ability to overlay areas or lines?  We have an immediate use for this for our workflows. Thank you, Kristen
