Desktop Survey Submission
1382
07-10-2023 10:21 AM
ClaireField
Hello, I am fairly new to Survey123 and I have been watching, reading, and some trial and error to create a survey. One request from the client ask to submit a survey on a Desktop through Survey123. I am using Survey123 Connect myself and I cannot submit a survey as I get a "data is valid" box and the survey will not submit. I wasn't sure if the survey was broken so I tried my phone and a tablet to test my survey. It works great, wonderful, and fantastic!
My question is: Is there a feature /code that is required to allow Desktop submissions through the Survey123 (or connect) Desktop application? (I am excluding the web services as my repeat functions are broken.)
KhemAryal
@ClaireField As far as I know, Survey123 Connect doesn't let you submit. You need to publish from the connect once you get "data is valid" (that means the survey form is all ready to publish) and test from the Survey123 desktop app (not the connect app) or mobile/browser.
KhemAryal
ClaireField
Awesome, thank you for the quick reply, I will test it!
ClaireField
Wanted to say, this was solved as Connect is the station to create, need the separate Desktop Software to submit.
