delete records in survey123 - ArcGIS Enterprise 10.9
657
10-06-2021 04:43 PM
PamelaLandy
Hello, I have cleaned records from my survey123 survey that works on my AG Enterprise. However, the DBA (oracle 12c) continues to see information from the table (FC) which originates the service for the survey. How can I delete these records without it nothing happens to my survey?
ZacharySutherby
Hello @PamelaLandy
I had tested on my end and I also see records I had deleted remain in my Oracle Enterprise Geodatabase even through they don't exist in the feature class / feature service. This seems to be on the ArcGIS Enterprise to Enterprise Geodatabase connection as Survey123 is correctly deleting the features from the feature service. I would suggest reaching out to Esri Technical Support and they will be able to assist with troubleshooting the behavior.
Thank you,
Zach
