Hi Phil, what’s different then? I just tried again, completed all the fields, saved the survey, opened it again in the Outbox, and the only field appearing other than the defaults is the Site name and the Observer. Then I sent the data and all the fields were correctly recorded. I’ve had to remove most of the “Required” options, because the form won’t send if they appear to be empty.
However, I asked another staff member to try the same survey and his worked fine, and a third staff member is still having problems with losing data in another survey. Most of the others (at least 5 more) are also having issues with data missing when reopening the survey from sent items or drafts.
I’m using an iPhone 7 with the latest software, I’ll try and do a bit more digging to see if I can see what ‘s different between us all. I might even try on my daughter’s android!
Regards
Jon Marks | Senior Analyst, Environmental Science
GREATER WELLINGTON REGIONAL COUNCIL
Te Pane Matua Taiao
2 Fryatt Quay, Pipitea | Wellington 6011
T: 04 830 4140 | M: 027 609 8912
www.gw.govt.nz
