I need to customize this message. "You have already taken this survey. Thanks!"
I am using survey123 connect and I have the setting only one submission is allowed per submitter.
Is there a way to customize it?
Thank you
Hi @RickeyFight ,
Yes, the submission screen can be customized in Survey123 Connect. Provide a note with the name generated_note_prompt_submitted and place the text you want to display in the label column. Refer to the documentation section on customizing form elements for more information.
@JamesTedrick this doesn't work for me. In fact, it disables groups with a condition in the relevant field so that they don't show at all.
@JamesTedrick I have "generated_note_prompt_submitted" and that is the thank you text after submitting a survey. I am looking for help with the message this setting gives.
I want to change this
@RickeyFight Were you able to figure out how to update the text that is displayed when only one submission is allowed? I'm trying to do the same update but cannot find the element to be customized.
Appreciate any help on this, thanks!
