Customize this: You have already taken this survey.
483
06-12-2025 04:03 PM
RickeyFight
MVP Regular Contributor
I need to customize this message.  "You have already taken this survey. Thanks!"
I am using survey123 connect and I have the setting only one submission is allowed per submitter.
Is there a way to customize it?
Thank you
JamesTedrick
Esri Esteemed Contributor
Hi @RickeyFight ,
Yes, the submission screen can be customized in Survey123 Connect.  Provide a note with the name generated_note_prompt_submitted and place the text you want to display in the label column.  Refer to the documentation section on customizing form elements for more information.
ZenMasterZeke
@JamesTedrick  this doesn't work for me. In fact, it disables groups with a condition in the relevant field so that they don't show at all.
RickeyFight
@JamesTedrick  I have "generated_note_prompt_submitted" and that is the thank you text after submitting a survey. I am looking for help with the message this setting gives.
I want to change this
