Custom Error Messages on Submission
1125
03-24-2023 06:49 AM
SteveGingerich
I've created a Survey with a my own feature service.  Within that feature I have validation rules to test the data. It prevents the data from being submitted when the data doesn't match my criteria.  However the error message that is posted to the user is so busy with error codes and layers of messages that my simple message is lost, which would likely make it very confusing to the user.
Is there a way to only display a simple error message?
This is via the web survey and created with Connect.
Thanks
ZacharySutherby
Hello @SteveGingerich
Survey123 returns the error returned by the server and there wouldn't be a way to modify the error from the Survey123 side.
Our recommended workflow would be to use the same logic you used for your validation rules in the constraint column of the XLSForm so that the validation occurs on the Survey123 side prior to submission. Using a constraint allows you to customize the constraint message which will be displayed in Survey123.
Thank you,
Zach
AaronPDXPaul
Hi @ZacharySutherby
Can you provide sample text that will modify the constraint message?
Where it changes the color, maybe makes bold, increase font size.
Also, the box for the message is light red, along with red text.
Can this box not be light red?
The image below sort of works.
But is not elegant and makes the user feel they've done something "wrong"
Thank you
