custom basemaps - tike package in survey123
1535
11
03-24-2019 07:28 PM
jasoncatlin
New Contributor II
I have created a tile package and loaded it into the map folder on my device but Survey123 is still using the ESRI basemap and not my customer basemap
by Anonymous User
Not applicable
Hi Jason,
Have you followed all the steps outlined here: https://doc.arcgis.com/en/survey123/desktop/create-surveys/preparebasemaps.htm
How did you create the .tpk file and how big is the file? What sort of devices are you using, please provide the make/model and OS version, and also what app version you are using?
Phil.
jasoncatlin
New Contributor II
Hi Philip
I did but the instructions were not clear on copying the snipet of code into my existing .info – step 3
Copy the following code snippet into this file, modifying the map sources section with your own shared tile package name and URL, and click Save. This snippet should be placed within the first layer of brackets in MySurvey.info.
Regards
Jason Catlin
AdamDaily
Occasional Contributor II
You wont see the default ESRI maps in the Maps folder that you load your .tpk files to, something like "C:\Users\UserName\ArcGIS\My Surveys\Maps".  Once your tpk is in here it should then appear in Survey Connect Settings where you can select your default base map "Settings\Map\Default Map Type". Once you change the default map, the INFO file within your survey design folder will update accordingly and this will become your default map when the survey gets published.
jasoncatlin
New Contributor II
Here is a copy of the info file once it was configured in Connect for Survey123
"displayInfo": {
"map": {
"coordinateFormat": null,
"defaultType": {
"name": "sweepbase3"
"home": {
"latitude": -37.830643,
"longitude": 144.96552,
"zoomLevel": 9
"preview": {
"zoomLevel": null
"style": {
"backgroundColor": null,
"backgroundImage": null,
"inputBackgroundColor": null,
"inputTextColor": null,
"textColor": null,
"toolbarBackgroundColor": null,
"toolbarTextColor": null
"imagesInfo": {
"captureResolution": 640
"publishInfo": {
"connectVersion": "3.3.51",
"webFormTransform": true
"queryInfo": {
"applySpatialFilter": true,
"mode": "",
"where": ""
"sentInfo": {
"enabled": true
"serviceInfo": null
Regards
Jason Catlin
0407048458
Jason.catlin@broadspectrum.com
Ten Rivers
by Anonymous User
Not applicable
Hi Jason,
You do not need to follow the shared tile package steps if you are not using a shared tpk that has been shared via your AGO org as an item. If you are simply copying the tpk to the maps folder via a browser or using the new file path chooser in the app Settings -> Storage to select a different folder on a SD card for example, then all the surveys should be able to view this tpk.
If you still can not see the tpk can you provide more info about the size, type, how you created it, os/device etc?
Phil.
by Anonymous User
Not applicable
I have this same problem. Survey123 Connect won't recognize the new basemap tpk. I've tried every method - tpk in the maps and media folders, online, modified the .info file.
Tools:
Survey123 Connect 3.3.51
Tile Package Kreator 1.3.30
Windows 10 x64 Enterprise 1803
tpk file size 5.6 MB
by Anonymous User
Not applicable
Hi Pam,
Are you able to share your xlsx file and the tpk file?
Phil.
jasoncatlin
New Contributor II
Hi Pam,
I was using the a older version of Survey123, once I downloaded the latest version my tile package worked perfectly.
Make sure you have the latest.
regards
Jason
by Anonymous User
Not applicable
Thanks Jason, I’ve been having a lot of trouble with survey123 so had already upgraded all my apps to their most current versions (survey123, connect, tile package kreator, arcgis pro). Unfortunately it didn’t fix anything.
