Creating Form From Existing Feature Service - Related Tables Not Populating
956
05-08-2024 11:34 PM
tiztrain
Hey all,
I have been wanting to use a specific data schema to create a survey123 form off. This dataset contains:
  • One spatial table (parent)
  • Multiple tables that use a mix of 1:1 and 1:M relationships
  • Tables that are connected to the second level of table
I have published this data structure as a service to AGOL and then created the survey123 form based off this service.
The result is a survey123 form that only conatins the schema from the parent spatial dataset and all associated tables are basically skipped. Looking at the article below, it looks like the XLSForm should automatically create the relevant entries for the associated tables, including repeats for the 1:M relationships?
Has anybody got this working successfully? I know I could add these in manually but there are a lot of tables so hoping I could do this automatically as much as possible.
Working with existing Feature Services in ArcGIS Survey123 (esri.com)
