Creating Cascade Effect based on multiple choice answers survey 123
1460
05-03-2022 08:07 AM
MeganWheat
I am working on building a survey in survey 123 connect. If a participant of the survey answers a multiple choice answer I want the particular comment boxes to populate. Is there a way to do that in survey 123? Or if they choose multiple choice of 1, 2 then comment box 1 and 2 will be required. Not sure if this is possible. But would love to hear your thoughts!
Megan
IsmaelChivite
Esri Notable Contributor
Here is an example that shows text questions according to the choices checked in the select_multiple. You could use a similar technique to make questions required.
IsmaelChivite
MeganWheat
Thank you so much! That did exactly what I hoped it would! 🙂
