Creating a unique ID in the Survey123 web designer
2520
03-22-2022 08:39 AM
DaveK
Hello,
Is it possible to create a unique ID field within the Survey123 web designer?
Any information on how to set it up would be appreciated.
Thanks.
IsmaelChivite
Esri Notable Contributor
Hi. It is not possible to create a Unique ID value right from within Survey123 web designer at the moment. However, when a new survey is submitted, ArcGIS always creates a unique sequential integer value in the ObjectID field.
IsmaelChivite
DaveK
@IsmaelChivite , Thanks for the info. I guess I'll stick with Connect for this project.
DougBrowning
MVP Esteemed Contributor
Does a calc of uuid() not work?  It is not in order but it is unique I think.
IsmaelChivite
Hi @DougBrowning    uuid() is not available in Survey123 web designer.
