Creating a survey in survey 123 that calls different questions based on field values
1240
02-07-2020 06:59 PM
MichaelOrfanos
I'm trying to create a survey that calls other survey forms based on a given attribute value in a specific field.
Field name:                  Area
Drop-down option:       North   >  links to survey form with 6 questions
                                    South   >  links to a different survey form with 12 questions
I have googled the hell out of it to no avail...
cheers,
Michael
Jing_Sun
Hi Michael,
If you can include all forms into one single survey, then using 'relevant' will be the best option. The idea is to hide the irrelevant questions base on the selection of the 'Area' question.
First add all questions into the survey, with your 'Area' question on top on all the other questions.
For questions that link to the 'North' answer, add a sentence like 'selected(${area},'north')' to the 'relevant' field of these questions, and do the same for those link to the 'South' answer, using 'selected(${area},'south')'.
But if your idea is to open another survey in the middle of a survey, the method I suggest is to use two apps: include your 'Area' question in the Collector, then open a Survey123 form from the Collector. Please see this page for more information: Integrate with other apps.
This blog about relevant is very useful: The art of hiding.
Cheers,
Sun
Jing_Sun
Hi Michael,
Cheers,
Sun
MichaelOrfanos
Thanks Sun, relevant seems to do the trick
cheers,
Michael
