Create Relationship Between Survey 123 Results and Point Feature Layer?
879
6
05-16-2025 08:51 AM
GC_GIS
I am trying to create a map in AGOL where one can click on a fire hydrant and view the related records in the pop up from a Survey 123 form. I don't want it to populate any fields in the original data - just show the inspection forms from Survey 123 in the popup for fire hydrants. I am having a lot of trouble figuring this out- any help is appreciated.
Thanks!
DavidSolari
MVP Regular Contributor
I'm unclear what your exact workflow is, but you can link to an existing survey form from a popup using an Arcade expression like this:
"https://survey123.arcgis.app?itemID=<your survey item id here>&action=view&q:globalId=" + Lower(Mid($feature.GlobalID, 1, 36))
For more info on what types of URL parameters you can include check out the docs. You can either add this to the related table's pop-up or use some more arcade to find the most recent survey entry and link to that from the hydrants, lots of options to play around with.
GC_GIS
Thank you for your help.
Sorry if i was unclear. What I would really like to do is have the survey 123 form populate a new table and create a relate between this table and the original fire hydrant feature service, then show the related records in the attribute for each hydrant.
DavidSolari
It sounds like you want to use Survey123 to add and edit records in a related table to the hydrant points. This blog post can get you started on linking a survey form to an existing table. You will have to build the table yourself but as long as you pay attention to the field names and data types this should be fine. You can then use app links like I mentioned above to give Field Maps users a quick link to Survey123.
GC_GIS
Do you know how to create a table from the Survey123 form that I can relate to the feature layer?
GlenterpriseUK
Hi @GC_GIS,
You might want to create new table using ArcGIS Pro that has the schema of your form and add a field that you can use for a relationship on the new table.
Then you might need to create a relationship class to link the Survey123 data with the Table that you create.
Regards,
Glen
DougBrowning
MVP Esteemed Contributor
I do this a lot.  Short answer is you download the form service as a GDB, add the parent, make a relate with your own key, publish this as a new service, point your form to this new service.  Then make sure to manage the keys yourself using URLs usually.
I have a bigger writeup here.  https://community.esri.com/t5/arcgis-survey123-questions/mapping-with-survey123-within-a-polygon-or-...
We use it a ton and it works great.
