Is it possible to create a notification pop-up in Survey123 Connect that you could require the user to sign-off on prior to accessing your survey? For example user must acknowledge the terms and agreements before they can move on to using the intended survey. Or the user must acknowledge the penalties that may apply for failure to comply with survey requirements. Any information on this would be greatly appreciated. Thanks!
