Create a feature template report on a related feature through a separate survey
936
05-24-2021 05:26 PM
Felicitychun
I have created a survey with a repeat feature in the parent with a repeat table. I have then created another survey that references this same feature layer but just to the repeat feature 1.
I am generating feature reports from the original but I also want to generate feature reports to the second survey so that each report is the on the repeat feature in the parent.
When I am trying to create the template I just get an error, even when I hit 'create sample template' or the 'quick reference' link.
I don't think its a server issue as I have been running the first report generation and editing and updating the other report template.
Is this a known issue? Is the relationship in the feature layer causing this?
JodyZhengLiu
Hi @Felicitychun ,
Do you still experience the issue? If so could you send a copy of the xlsx form for us to reproduce? (zliu@esri.com)
Jody Zheng Liu
Felicitychun
I was able to add the work doc template into my portal content and run it.
I just couldn't run syntax checks.
Thanks
