count() and sum() functions for repeat in Inbox
4781
11
05-16-2018 11:22 AM
BrentKinal1
Is it possible for count() and sum() functions to work for ALL repeats reported with a survey, including those previously sent, when revisiting a survey via the Inbox?
JamesTedrick
Esri Esteemed Contributor
Hi Amanda,
Can you see if the sample attached properly represents the workflow you are trying to implement?  It appears to be working properly in this sample.  BTW, you can attach files by going into the advanced editor in the comment box.
AnthonyJonesRSK
Hi Phil, sorry for piggy backing on an old post but I'm still experiencing issues with this now. I have a count calculation in my parent record for repeats and when accessing surveys from the inbox it won't take into account those repeat records from previous surveys. If I add new repeat records these are included in the calculation. I have "allUpdates=true query" for all my repeats so I would have expected all repeat records to be included in the calculation. Is this the expected behaviour? Thanks
