I have a date field in my survey that I would like to keep hidden. I am using a calculation on the field now(). However if a user does a "copy the sent data to a new survey" the date and time does not update to what is the current time should be. It keeps the date of the survey being copied. Is there a way to turn OFF copy the sent data while still allowing the surveys to be saved to the device? Sometimes the user needs to edit an already sent survey so that function is critical to keep. OR is there a way for the date field to update when a "copy the sent survey" is created?
