Copy survey from Inbox does not pick up username?
777
02-04-2021 10:45 AM
TL2
Is this by design?  When I go to collect I can see the username as a note.  When I copy an existing survey from the Inbox the username function does not work?
Shwu-jingJeng
What version of the field app are you using? Did you create a username field and a note field to read from that user name field in the XLSForm?
If you could share the XLSForm with us to see how the username was specified in the form, that would help us to identify the issue.
